Divide
palmfikret
Is there a divide part command like in autocad? what is the way to divide a line evenly
Split command (ax icon button):
https://help.graphisoft.com/AC/26/INT/index.htm#t=_AC26_Help%2F030_Interaction%2F030_Interaction-85....
in conjunction with snap guides:
https://help.graphisoft.com/AC/26/INT/index.htm#t=_AC26_Help%2F030_Interaction%2F030_Interaction-49....
AC 28 USA and earlier   â€¢   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
1 REPLY 1
