Door Hinge markers showing and can't get material to show 3d
Hello everyone, I am pretty new to ArchiCad. I have a layer turned on that is making the door hinge points as well as little blue arrows on the windows. I am also having problems assigning materials to my floors/slabs. Thanks for any help in advance!
4 Replies 4
vistasp
What you have turned on is a setting in your Model View Option (MVO) which control the display of opening lines among other things.
Read about is here.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Thank you so much. Greatly appreciated.
David Maudlin
In the Slab Settings > Model panel > make sure the Override Surface button is active (grey), then the Surface pop-up list to change the Surface(s) will be available.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Ok so I have actually gone into the model and made these changes and it worked. Thank you again. Greatly appreciated. I went into the Document-Set Model View Options...-Miscellaneous Setting for Library Parts-Show Opening Lines in 3D Projections- Then I clicked the options off for doors, windows, and skylights. Just wanted to state this clearly for anyone else that is may have this problem.
