yesterday
I tried to remove the grey fill in the Door plan, I tried all the settings but I couldn't do it. I am using educational version
Solved! Go to Solution.
yesterday
The setting you are looking for is under Document>Model View> Model View Settings.
Then under the tab for Miscellaneous setting for Library Parts, uncheck the Minimum Space of Door & Object toggle box.
I can't remember if 27 moved that to a different panel in the MVO settings. But it should be within this dialog.
yesterday
yesterday - last edited yesterday
yesterday
thank you Jeff, this just worked
yesterday
So sorry, I didn't give much attention to the attached image.
Yes, @JeffH's reply is the right one, thank you all.
yesterday
thank you Mahmoud for your answer, this help with fill display
