M-Majeed
Door Opening Fill in 2D
I tried to remove the grey fill in the Door plan, I tried all the settings but I couldn't do it. I am using educational versionDoor- 2D.jpeg
1 Solution
JeffH
The setting you are looking for is under Document>Model View> Model View Settings.
Then under the tab for Miscellaneous setting for Library Parts, uncheck the Minimum Space of Door & Object toggle box.
I can't remember if 27 moved that to a different panel in the MVO settings. But it should be within this dialog.
AC24 / AC26 / AC27
Win10
Go to post
5 Replies 5
JeffH
AC24 / AC26 / AC27
Win10
Hi @M-Majeed@JeffH,
Here’s to find how to disable the fill display for AC 28 but for 27 I think only uncheck that option (Use Fills).
AC 29 INT 4006/WIN 11
M-Majeed
thank you Jeff, this just worked
So sorry, I didn't give much attention to the attached image.
Yes, @JeffH's reply is the right one, thank you all.
M-Majeed
thank you Mahmoud for your answer, this help with fill display
