ā2024-10-08
05:22 PM
ā2024-10-13
01:13 AM
I tried to remove the grey fill in the Door plan, I tried all the settings but I couldn't do it. I am using educational version
Solved! Go to Solution.
ā2024-10-08
06:09 PM
ā2024-10-13
01:14 AM
The setting you are looking for is under Document>Model View> Model View Settings.
Then under the tab for Miscellaneous setting for Library Parts, uncheck the Minimum Space of Door & Object toggle box.
I can't remember if 27 moved that to a different panel in the MVO settings. But it should be within this dialog.
ā2024-10-08
06:09 PM
ā2024-10-13
01:14 AM
ā2024-10-08
06:35 PM
ā2024-10-13
01:15 AM
ā2024-10-08 08:30 PM
thank you Jeff, this just worked
ā2024-10-08 08:54 PM
So sorry, I didn't give much attention to the attached image.
Yes, @JeffH's reply is the right one, thank you all.
ā2024-10-08 09:16 PM
thank you Mahmoud for your answer, this help with fill display
