License outage
Dear Customers, We are facing with an outage in our services in Azure. You may experience issues with the Azure-based functions, like licensing, BIMcloud SaaS, Learn Portal. We are working hard on this issue to make it fixed as soon as possible. Thank you for your patience.
Door Window Marker
How & where do I save a custom door/window marker?
I see a "load other window-door marker" option but it leads nowhere.
4 REPLIES 4
TomWaltz
Can you be a little more specific? Where are you seeing these prompts?
Tom Waltz
Window (or Door) Selection Settings/ Dimension Marker/ Window Marker pull down menu. Different marker types can be selected, and there's a "Load Other Door-Window Marker" selection.
So I'm figuring there's a way to save all my custom edited selections for the marker as a sort of favorite. That's without saving the window itself as a favorite—basically I want to use the same marker with different windows without having to edit a dozen or so parameters.
Thanks!
If you go to File\GDL Objects\Open Object by Subtype, you get the Dialog in the attached image.
Here you can find the Window-Door Markers, and you can open them for editing, Save as another name to any place you want, and you can modify that.
If you save it into a loaded library you will have in the list of selectable Window-Door Markers, so you don't have to search for it with the Load other Window-Door Markers command.
Awesome—Thanks!
