Door impossible to assign renovation status
alessiofazzi
I am tryng to give a door a renovation status but all the three option are greyed out. Any suggestion?
The door is a child of the wall, you probably need to set the wall to existing first.
Stefan
AC ...-29, WIN10
5 REPLIES 5
Eduardo Rolon
Renovation Status is assigned using the "Renovations Palette" not selected in "Door Settings".
Open the palette under the Window Menu.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thank you for your answer Eduardo, I know how to assign the renovation status, i have the palette exposed, as you cansee in the pic (top - right corner) but all the options are geyed out
Stefan
AC ...-29, WIN10
To add some more detail to what @Stefan L_ wrote:
The Renovation Status of the Wall may limit what the Renovation Status of the Door/Window can be.
  • If the Wall's Renovation Status is "Existing", the Renovation Status of the Door/Window placed into it can any of the 3 possible values.
  • If the Wall's Renovation Status is "To be Demolished", the Reno Status of the Door/Window will be the same as that of the host Wall ("To be Demolished"). - If you demolish the Wall, the Door/Window will also be demolished.
  • If the Wall's Renovation Status is "New", again, after placement, the Reno Status of the Door/Window will be the same as that of the host Wall ("New"). - You can only place a new Door/Window into a new Wall.
So, when the Wall is not Existing, Archicad will force the placed Door/Window to have the same Reno Status as the Wall, regardless of what default Reno Status was set for the Door/Window before placement.
The below image shows the 5 possible combinations.
My italian is very rusty… 😉
AC29 US/INT -> AC08
another Moderator
Setup info provided by author
