2025-11-03 01:29 PM
I am tryng to give a door a renovation status but all the three option are greyed out. Any suggestion?
Solved! Go to Solution.
2025-11-03 02:14 PM
The door is a child of the wall, you probably need to set the wall to existing first.
2025-11-03 01:39 PM
Renovation Status is assigned using the "Renovations Palette" not selected in "Door Settings".
Open the palette under the Window Menu.
another Moderator
2025-11-03 02:04 PM
Thank you for your answer Eduardo, I know how to assign the renovation status, i have the palette exposed, as you cansee in the pic (top - right corner) but all the options are geyed out
2025-11-03 02:14 PM
a month ago
To add some more detail to what @Stefan L_ wrote:
The Renovation Status of the Wall may limit what the Renovation Status of the Door/Window can be.
So, when the Wall is not Existing, Archicad will force the placed Door/Window to have the same Reno Status as the Wall, regardless of what default Reno Status was set for the Door/Window before placement.
The below image shows the 5 possible combinations.
a month ago
My italian is very rusty… 😉
another Moderator
