Door marker text problem
When I place door or window in some walls, their marker text is reversed. I have replaced the walls but it helped in few cases only. Kind of annoying glitch, which I do not know how to fix. Markers in the other walls "behave" correctly.
On the attached screen shot 240/220 should be read from right not left.
5 REPLIES 5
check out renovation status for walls and doors...
In my START Edition I do not have renovation feature available.
Stress Co_
Check to be sure your wall is perfectly parallel to the "X" axis.
If it is angled, even a small amount, .... the text will rotate.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Maybe this might help if the wall is perfectly horizontal.
Select the wall and then go to OPTIONS > MODIFY WALL > INVERT DIRECTION.
Thank you Barry and Mark,
I have checked the walls in question and, of course, they were off by a a minuscule angle fraction (0.01 degree).
Thank you both again,
