‎2005-03-31 05:29 PM
‎2005-03-31 05:34 PM
‎2005-03-31 06:06 PM
‎2005-03-31 06:12 PM
Matthew wrote:What is puzzling is that for example in my screenshot the detail positioned over the D area is labelling it's self C and even if I tell it to reset the Autotext Reference point to a corner in the D area it still displays C in the Title label which I highlighted in my screenshot
The problem is not entirely clear from your posts. But, I am guessing that it has to do with the positioning of the drawings on the sheet.
‎2005-03-31 06:34 PM
‎2005-03-31 06:38 PM
Thompson, wrote:But you should be able to change it from the bottom left to any corner you like by using the pop-up menu item. Sadly it doesn't seem to be working for me
The drawings are numbered based on their lower left corner position. Whichever numbered grid square contains that corner of your drawing will be the number plotmaker assigns.
‎2005-03-31 07:12 PM
‎2005-03-31 07:19 PM
‎2005-03-31 08:24 PM
fuzzytnth3 wrote:Look at this wish an vote for it:
That sort of worked now one of the other details is now wrong due to it spreading across two cells. The result is I have details labelled A, B, C, D, F and G whereas before I had A, B, B, C, E G
I still think there is glitch though because according to the manual you should be able to set it yourself for each individual plot file by using the pop-up menu.
‎2005-04-03 12:45 AM
