2018-04-05 09:57 AM - last edited on 2023-05-25 05:36 PM by Rubia Torres
2018-04-24 08:13 AM
2018-04-24 08:32 AM
2018-05-05 05:46 AM
Brett wrote:The thing is, wherever you have a slab-on-grade you also have thickened slab under some walls, sloped slabs, slabs with turned down edges...you need to select elements that when used together will display the dashed lines you want with out having to draw any lines at all. I make foundation plans all the time with no lines. https://www.screencast.com/t/SXqGQVWRHPtl
Come on Steve, please answer your own questions and the reasons why you wouldn't use slabs. He's a new user and you have totally confused him as well as me. Make it a teaching session.
Unfortunately, Archicad is sadly lacking quality tutorials on this sort of thing. They show you what the tool is for and how to use it but none of them explains the reasoning of using it one way for better results further down the line.
I know Barry is the number one helper on this forum and hasn't the time to explain in this case why one way is better than the other, especially down the line for document output.
This is relevant for most of the tools in Archicad.
There is an opening for someone like you Steve to record and explain all these little rules (as in this question) in short tutorials at a minimal cost to the new (and existing) users.
What do other users think? cheers
