ā2004-08-24 05:58 PM
ā2004-09-07 05:24 PM
Nathan wrote:One other thing to note is if you switch on Special Snap Points and enter a distance you can use this to measure along an arc a specific distance and then bung a hotspot on the measured point to then allow you to generate further geometry from that point.
Is there any way to draw a precise Arc length using Archicad?
ā2004-09-07 06:57 PM
ā2004-09-07 07:11 PM
Seiss wrote:Ahh you want blood
FUZZYTNTH3 -
I have tried the Arc Tool and it works quite well. Now, how do I hide the dashed radius lines. Radius lines are okay for some uses, but on a survey drawing the radius lines will overly clutter the drawing.
Seiss
ā2004-09-08 03:29 AM
It could even just show a cross hair target for the radi point instead. What would you prefer?Actually all you need is a hot spot at the radi point, then you could "bung" it if you needed repeat radii. '
ā2004-09-08 12:40 PM
Seiss wrote:Here ya go I've tweaked it so the lines can be any colour you want and also visible or not.
FUZZYTNTH3 asked:It could even just show a cross hair target for the radi point instead. What would you prefer?Actually all you need is a hot spot at the radi point, then you could "bung" it if you needed repeat radii. ':wink: '
Seiss
ā2004-09-09 06:50 AM
Here ya go I've tweaked it so the lines can be any colour you want and also visible or not.Okay, I got it, I tried it, I like it....... Thanks for the effort
ā2004-09-09 11:07 AM
