2006-06-14
02:21 AM
2023-05-26
03:28 PM
Rubia Torres
2006-06-16 05:59 AM
Scott wrote:You need to download this from the graphisoft web site and then load the add-on. Go to your help menu in Archicad and chose goodies. This will take you to the location that you can download this and other add-ons
Steve,
I'm sorry to bother you with this, but we have the same AC10 build but I don't have the Grid Element Tool as an option in the Tool Settings DB, and I don't see it in the Add-ons folder. Any other thoughts at your convenience?
Thanks,
Scott
2006-06-22 09:00 AM
2006-06-22 04:18 PM
2006-06-22 04:45 PM
2006-06-22 04:59 PM
2006-06-22 05:06 PM
Do you know of a way to set the default update drawing to 'Manual' when placing drawings?No, but I was able to select multiple Drawings in the Navigator (Ctrl-Click) or the Drawing Manger and then change all the settings at once.
2006-06-22 05:23 PM
2006-06-23 02:02 AM
David wrote:This stops AC from automatically updating drawing contents everytime you change layouts but it does not stop the computers need to redraw/refresh the screen contents everytime you move around on or between layouts. This can take a considerable amount of time for drawings containing a lot of information like lines and hatches. This is why being able to set drawings to preview in Bitmap or Outline on the layouts was so useful as it substantially reduced the amount of information to redraw.
To be able to see your drawing without it updating every-time you open the Layout, change the "Update Type" from Automatic to Manual.
Use the Drawing Manger to check and update the drawings, or right click on the drawing to update.
2006-06-23 02:39 AM
In v9 we could set them all to Bitmap/Outline and have near instant response - but not anymore in v10. Doing the same work in v10 is taking me 5x> longer than it did in v9 because of only this.I know this is not the answer you're looking for Owen, because On-screen View Options are global (the same whether you're in the modeling environment or the layouting environment), but does unchecking the 'Vectorial Hatching' help you any?
2006-06-23 02:59 AM
