Drawing editing
Hi all,
is there a way to edit (on a line to line basis) an archicad drawing?
Please help.
10 Replies 10
Djordje
zoltar wrote:
Hi all,
Please help.
Hm? Line to line?
Yes, if it is drawn in lines. If it is walls, and other ArchiCAD stuff, then no.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Erich
zoltar,
That really depends on what you want to change. As already said, line by line can't generally be done as you are, or at least should be, dealing with modeling parts not lines.
However, you can change the parameters of the parts, line types, line colors, materials, composite wall assemblies, fill patters, etc. So what do you want?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
On previous projects I exported the plans, elevations and sections as dwg files to be edited in Autocad. Lines were erased, fills were edited etc. Just wondering if the same could be done with Archicad.
Thomas Holm
it doesn't seem to be the most efficient way to work, but to answer your question, if that is really what you want to do, you can export any view to a dwg file, open that, edit, and save as dwg, everything within Archicad.
if you just want to convert 3D items (walls, slabs, objects etc.) to 2D, you can explode them.
But since you lose all intelligence in the parts, this is a route I'd avoid as long as possible.
Dwight
And any section or elevation can be a "drawing" instead of a linked model view. Just lines and fills. No exporting required.
Dwight Atkinson
Thanks Thomas I'll try your method as it seems more straightforward. Dwight do you mean-as Thomas suggested- I explode the 3d elements? What do you mean when you say
"drawing"?
Dwight
In the Section tool dialog the Status option can be "Drawing."It produces unlinked lines. Go experiment for yourself.
Dwight Atkinson
Dwight it works like a miracle! Exactly what I wanted. Thank you for the tip.
Dwight
In Canada, guys named Zoltar are usually magicians, so learn some more miraculous things that we can share.
Dwight Atkinson
