Mr_X
Dwg terrain importing
Hello guys, im new on this forum.
Today I've recieved from Geodesist dwg file from terrain. In this file i see this points with numbers of height but when i look this terrain from the sides it is flat terrain but its not (its 1-2m difference) , of course when i import from autocad the terrain is flat. Is it maybe this failure from geodesist or?
Thank you. Greetings.
These articles should help you bring your DWG in as 3D geometry:
How to Open and Save 3D DWG or 3DS Files:
https://community.graphisoft.com/t5/Data-Exchange-articles/How-to-Open-and-Save-3D-DWG-or-3DS-Files/...
Converting 3D DXF/DWG Files into GDL Objects:
https://community.graphisoft.com/t5/Design-articles/Converting-3D-DXF-DWG-Files-into-GDL-Objects/ta-...
