Edit Story Level
Hi All,
I want to floor height range in Story Level Editing,
Ground floor elevation changes occur.
How can I increase the height change on the ground floor but all the other elements of the object on the floor above it does not have to go up or down automatically?.
The only change is to the distance Level Story but did not make all of the above objects go up or down.
Expect in this forum can help me for this solution.
Thank you.
6 Replies 6
Dwight
You want to lower the ground floor level?
Dwight Atkinson
Hi Dwight,
I want to raise the ground floor
Dwight
This is so rudimentary that i am concerned about understanding you.
You'll work in "Story Settings".
Raise the ground floor level and reduce the floor-floor height to the next floor level.
Dwight Atkinson
Thanks Dwight, I understand about the story floor setting.
I made ​​the design for the 19 storey building.
Ground Floor Height 7 meters, level 2 = 4.5 meters. Floors 3-19 = 4.5 meters
Say all the objects on the upper floors have been made complete, and I want to change the height of the raised ground floor plus 125 centimeter height of 7 meters to 7.125 meters high and I subtract a Level 2 = 4.375 meters. High floor 3 to floor 19 onwards remains unchanged.
By changing the ride height of the ground floor of 125 cm on floor setting this story would raise practical as well as all things that exist on the floor 2, 3 and so on will go up 125 centimeters change.
How can I make all things interior second floor did not go up above 125 centimeters by changing the floor height changes that occur in the ground floor and second floor.
I raise the height of the ground floor, all the objects on the floor 2, 3-19 will go up simultaneously.
Maybe I should go back to manually raise and lower it back?
I know that this will automatically apply when added up nor when it will be reduced then it will go down.
There are some objects that are exceptions and I want this object does not change altitude level.
David Maudlin
One option is to select those objects and change their Home Story to the Ground Floor.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hi David,
Thank you,
I did for the given object and it can be applied.
