2014-12-16 08:47 PM
2014-12-17 03:09 AM
2014-12-17 03:39 PM
2014-12-18 04:28 AM
2014-12-18 06:26 PM
2014-12-19 03:23 AM
2014-12-20 07:18 AM
"DSquad96" wrote:
I've made a truss in truss maker that is repeated several times in the model. If I go to make changes to the truss (from timber to steel construction for example) how can I make it so it applies to all instances of the truss rather than only the selected instance
2014-12-20 03:41 PM
Kamelite wrote:You can do this already using either by either creating objects or using modules. Different procedure but same result.DSquad96 wrote:A bit OT but still, among other software, 3D studio max has a function that lets you copy, say, a truss, but it is still linked to the original in such a way that if you edit the original, every instance of that object will change accordingly. Very much like the behaviour you are looking for. And here comes my point: could someone in the GS-team add this function to the wishlist for release 19 or 20 or whatever? I think this function would be very much appreciated
I've made a truss in truss maker that is repeated several times in the model. If I go to make changes to the truss (from timber to steel construction for example) how can I make it so it applies to all instances of the truss rather than only the selected instance🙂
.Thag
another Moderator
