Element Grouping
How do I separate three elements that seemed grouped, yet when I use suspend grouping they are still together. The object started as a shower cabin that I converted into morph to keep what I need. After deleting what I do not need, I am left with three morphs, shown in red arrows, that I cannot seem to separate them, even if I suspend grouping. What do I need to do to be able to delete one of the remaining morphs without deleting the other two I want to keep? Thanks.
NCornia
Graphisoft Alumni
Graphisoft Alumni
Cheikh,
When an element is split into Morphs the algorithm might group seemingly separate elements, but there maybe something underlying in the element's code that treats these elements as a single morph. In your case the elements of the shower hardware all comprise a single Morph. Select the Morph and use the Split command to cut the Morph in to 3 distinct parts.
I hope this helps.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Nicholas,
Thanks. It worked.
