rob2218
Elevation 'shadow' settings - does it reference the model?
My boss had a question.
He said that with Archicad being so sophisticated he couldn't see having shadows created on an elevational view NOT match the shadows that are assigned to the 3d model as well as the direction of the North arrow setting.
I told him that the elevational shadows were only a "graphic" technique and that you were able to manipulate the shadows in a per elevational tag setting but that they didn't automatically relate to the 'sun orientation' on the project.
Can someone please confirm this for me?
thanks....
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
3 Replies 3
Erwin Edel
Elevation Selection Settings > Model Display > SUN AND SHADOWS > Viewpoint Sun Settings > As in 3D window
Is that what you're looking for?
We use custom shadows on 45 degree just to show depth. North elevations would just be one big blob of shadows otherwise.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
rob2218
thanks for the quick response.
Soon after I hit the "send" key...I noticed the "custom" small arrow to the right of the elevation tag shadow setting........but yes, this is what I was looking at.
I did also note that if you set the elevational marker to "As in 3d window" it does create a big blob on the shade side of the building that is not in sunlight.....
So, the question then beckons...due you set the 'elevational shadow' setting associated to a 'viewmap' or not?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Link
For schematic elevations, shadows are typically used for aesthetics and definition, and so are set per elevation, not from the sun settings of the 3D window.
If you are doing shadow/shading studies, then the 3D window sun settings may be more appropriate.
Link.
