โ2005-04-13 12:23 AM
โ2005-04-13 06:55 AM
โ2005-04-13 09:24 AM
Assieh wrote:Do you have vectorial 3D hatching and/or vectorial sun shadows turned on?
We seem to have a problem when we update our elevations from the model it come up with an error message:
Error in Analytical shading method
Error Code-108 ( not enough room in heap zone)
When we turned off the shading in section/elevation tool box it finished rendering obviously without the shading. we did not have this problem before, and we have not changed anything drastically.
I would appreciate your help!
โ2005-04-13 06:18 PM
โ2005-04-14 06:10 PM
Assieh wrote:Set the minimal swap file to three times physical memory; what is the physical memory, BTW?
Our Archicad is the latest version of 9.0 -build 1965. Yes if I turn off vectorial shading it works. we do have a complex building to be rendered
โ2005-04-14 06:42 PM
