Error in 3d window
I was working in archicad 9.0,but not satisfied because of shortage of addons,when i saved archicad as 8.1 file ,and when i work on Archicad 8.1
Iam not able to see complete 3d window,But if i select only a wall and check 3d window then iam able to see the wall,please check this problem.
regards
ashok
1 REPLY 1
Link
Maybe you should check Image>Elements to Show in 3D? That'll be a good starting point. There's no difference here between 8.1 and 9.
Where in India are you?
Link.
