Error message with trim turned on
Has anyone else out there had a problem with the trim causing problems in 10? I have been using the template 10 for US content and everytime I put in a window with trim associated to it, I get the message "group operation error at line 879 in the 3D script of file wa_trim_us_10.gsm...it doesn't matter if it is a casement, double hung, awning, etc, as long as there is trim, I get the message. I have tried doing a new and reset, but I still get the same message. Any suggestions out there??? I sent an email to tech support a while ago, and they are aware that this is a bug. I'd say a pretty BIG bug!!! Any help would be appreciated!
31 Replies 31
TomWaltz
A small clip for reference:
Tom Waltz
I've run into the index number error and it appears to be a difference in the way profiled walls treat the wall skins. I haven't had time to look into this too deeply, but I haven't found any way as yet to get rid of it by parameter settings alone. (I have zero interest in fixing the macros in the AC10 library.)
The group operations error seems to be a bit more pervasive. I had it pop up during the beta period on a toilet that I wrote. I'm sorry to hear that it is still happening. The fix for the toilet was pretty simple, but again it's not anything I want to get into in the AC10 parts.
