Error message with trim turned on
Has anyone else out there had a problem with the trim causing problems in 10? I have been using the template 10 for US content and everytime I put in a window with trim associated to it, I get the message "group operation error at line 879 in the 3D script of file wa_trim_us_10.gsm...it doesn't matter if it is a casement, double hung, awning, etc, as long as there is trim, I get the message. I have tried doing a new and reset, but I still get the same message. Any suggestions out there??? I sent an email to tech support a while ago, and they are aware that this is a bug. I'd say a pretty BIG bug!!! Any help would be appreciated!
31 Replies 31
gkovacsp
Can't see it.
I had seen this behavior early on and tried to repeat it, but everything seemed to work fine. There isn't any chance you are using RC10 versus the final release?
David Pacifico
I have seen this error mostly in complex walls. There have been others reporting this:
http://archicad-talk.graphisoft.com/viewtopic.php?t=10893
http://archicad-talk.graphisoft.com/viewtopic.php?t=10903
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
I am using the most current copy of Archicad. I had just installed a new-out of the box copy yesterday and I started having these problems right off the bat. Gabor, did you open the file? Did anyone else try opening the file?
TomWaltz
You did not post a file. Your message did not have any attachments.
Tom Waltz
It won't let me send it, it says the file is too big. I don't know why, the file is only a little over 1 MB.
Is anyone else here using, or has used the AC10 template for US users??? I found that when I did a new and reset and pasted in the old model that my doors and windows work. But everytime I go into that template I get the same error. Does anyone know a way to import the layout book/ project map from a different pln info into a new file?
archicad-talk.graphisoft.com/attach_rules.php?f=2
Kinda restrictive for big-filed folks like ourselves but there you go.
James Murray
Djordje
Do a "forwad merge":
- make a template of a New and reset file
- merge the template into it
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
In the Attribute Manager, purge all unused attributes.
Also, delete everything except for a Wall with the problematic Window in it.
Then save as PLA and ZIP it.
Then hopefully it will be small enough.
