‎2007-07-17 12:38 PM
‎2007-07-18 12:34 AM
Keith wrote:this has been happening to me since AC9 i think. ESC and DEL stop working intermittently - and for no obvious reason. the only cure is to restart archicad i'm afraid.
My Escape key has stopped working. This only happens in Acad 11, not in Acad 10.
‎2007-07-18 02:11 AM
~/archiben wrote:Or, while your archicad is still open... try clicking on your 'active' archicad's shortcut..(mine is located on the dock...others may have theirs on the desktop screen). It somehow 'refreshes' the whole window environment, especially if you tend to navigate in and out of your archicad window to do other tasks... its worth a shot, it helped me a few times.Keith wrote:this has been happening to me since AC9 i think. ESC and DEL stop working intermittently - and for no obvious reason. the only cure is to restart archicad i'm afraid.
~/archiben
‎2007-07-18 09:47 AM
‎2007-07-25 05:06 PM
‎2007-07-25 05:45 PM
‎2007-07-25 05:57 PM
‎2007-07-25 06:09 PM
‎2007-07-27 11:01 AM
‎2007-07-29 11:57 PM
Keith wrote:just as a matter of interest: if you go into your work environment>keyboard shortcuts and try to assign the ESC key to a command - any old command - what does it tell you?
Escape key still doesn't work (except, oddly, in Text Edit mode). Only way to abort a command is to finish it and then undo. Pain in the neck!
