Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. License Manager Tool update is required on Windows. Learn more…
2017-03-1110:41 AM - last edited on 2023-05-2302:18 PM by Rubia Torres
I have to draw a roof plan where the projection direction is perpendicular to the roof plane. (Since it was a plan view but the projection is not vertical but sloped.)
Is it possible to give the a direction exactly (ie to draft it) for a general roof (ie not sloping, say, 45.0000 degrees)?
I mean not measuring the roof slope and enter it to the axonometry input box as a number.
You can set camera positions in the 3D projection settings window. You can also choose to look perpendicular to a selected surface. Whilst in the 3D window, parallel projection mode, go to menu View > 3D view options, or > 3D navigation extras.
