Export & import work environment profile
I am trying to set up Archicad on a new computer and want to import my work environment from my old computer. I am using version 16. I can export my WE from the old computer (as an XML document), but when I try to import the WE, the Import function doesn't seem to be able to recognize XML documents. I have exported WE in the past using version 16 and they were saved in a windows folder structure and I can import those work environments. I am confused - please help.
1 REPLY 1
Eduardo Rolon
Just select the folder, AC will recognize the XML file within it.
No need to select the XML file.
Strange quirk but you get used to it.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
