ā2021-10-06 10:27 AM
Hello Folks š
I draw a multi-storeys building and I need to export it in dwg. When I visualize, for instance the second floor, and export it to dwg, the file I get shows all the elements underneath the selected floor I am exporting. So, while in Archicad, the floor plan is clean, in autocad, it shows the second floor overlapping the 3 floors below.
How can I do?
Solved! Go to Solution.
ā2021-10-08 07:59 PM
I managed to solve the problem! I had to select each element on each floor and in "Floor Plan Display" select "Home Story Only". In this way I have a dwg drawing clean and tidy exactly the same I visualize in Archicad. Thanks anyway a lot for the support!
ā2021-10-06 04:38 PM - edited ā2021-10-06 04:39 PM
Hello Stevini,
You have to prepare a layout with all your level plans and publish this layout with the right DWG export translator. By this way you are able to get all your level plans into the "Object" space into Autocad.
ā2021-10-06 07:19 PM
So I create one layout drawing which inclused 4 plans of my building, I save the drawing in DWG, and the result is the same as the previous one. Any wrong passage? Btw I am using Archicad 25
ā2021-10-06 07:28 PM
Yes wrong passage about dwg translator parameters. š¤
ā2021-10-06 08:44 PM
I am editing the paramenters. I do not find any parameter which includes only the visible items. The only thing I find is visible layer but it doesn't work because the layer of the walls are the same in every floor. There isn't any straight forward and preset way to have a dwg clean as tidy as in the viewport in Archicad?
ā2021-10-06 09:01 PM - edited ā2021-10-06 09:01 PM
English is not my birth language, I'm not able to explain you as well as I want. Share you file and I will do it for you.
ā2021-10-06 09:11 PM
well.. thank you very much! I cannot attach .pln files here so I will attach a link to wetransfer:
ā2021-10-06 09:51 PM
Into AC you should put all your level plan views into one layout
Then add this DWG export translators into Archicad before publishing DWG :
https://fromsmash.com/all-dwg-into-one
It seems to be like this :
All your level plan views into Autocad "Object" space through one publication.
Is it what you need ?
ā2021-10-06 10:15 PM - edited ā2021-10-06 10:16 PM
Then you are able to change hatches, lines or pen type correspondences between Archicad and Autocad. It's possible to export windows, doors or cut hatches into associated layers too.
I don't know how to use all-dwg-into-one.xml
