2016-01-20 07:50 PM - last edited on 2023-05-26 03:53 PM by Rubia Torres
2016-01-21 01:45 AM
2016-01-21 04:22 AM
2016-01-21 11:47 AM
David wrote:
Hi Paopao
Exactly what do want to export and to what?
Are you exporting to another ArchiCAD file or another software?
2016-01-21 11:51 AM
Bruce wrote:Thanks! That may be the procedure I am after! I am going to try it.
If you want to export layer definitions, use the attribute manager. If you want to export the content on particular layers:
1. Turn on what you want - turn off everything else
2. Use the thick marquee to select everything
3. Go to File > External Content > Save selection as module
You can then open and save as a pln, or import into another file and break the link.
To merge layers, just delete one, and you will be asked which layer to place the content onto.
