Exterior & Interior Wall Intersecting Issue
Jim
The exterior and interior walls are not intersecting properly on my drawing. I am new to Archicad so this is most likely a simple fix but I don't want to waste anymore time on it so here I am.
I seen a few other posts talking about Building Material and Intersection Priority but its either not working or I'm not adjusting these settings properly.  
Any help is much appreciated.
Archicad Version 28
Intel Core™ i9-14900KF (68 MB cache, 24 cores, up to 6.0 GHz P-Core Thermal Velocity)
Windows 11 Home, English, French, Spanish | NVIDIA® GeForce RTX™ 4090, 24 GB GDDR6X
64 GB RAM: 2 x 32 GB, DDR5, 5200 MT/s | 2 TB, M.2, PCle NVMe, SSD
The Building Material you have used for the insulation element of the wall needs to have a higher priority than any element of the interior walls. Where two composite walls intersect the layers of the composite wall which have a higher priority will cut those with a lower priority.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
4 REPLIES 4
Lee Hankins
If you upload some screenshots of your composite setting for each of the wall types you have used it will be easier to help you adjust them. Also, if you select one of your composite walls and then open the Building Materials settings under Options, Element Attributes, Building Materials, all those in use by the selected composite will be highlighted green to make it easier to find and adjust them. You can then order the list by the priority setting and adjust the values.
Lee Hankins
Thank you! That worked!
Archicad Version 28
Lingwisyer
Guru
Regarding the one spot where you internal wall did not penetrate your external wall, make sure your Reference Lines are intersecting consistently.
Setup info provided by author
