‎2005-08-25 05:27 PM
‎2005-08-25 05:46 PM
‎2005-08-25 08:45 PM
‎2005-08-25 08:55 PM
kaykay wrote:A few possibilities:
hey
I am using version 9. It does not automatically take the properties of the selected object. eg. if i want to draw a window similar to what i have drawn before, the tool doent pick up the properties of the window i want to match with.
what do u think might be the problem?
kay
‎2005-08-26 05:49 PM
‎2005-08-28 06:31 PM
Link wrote:If it does not honk, the parameters are not transferred ... as simple as that!
Good thinking Tom. Although I think the official term is a 'honk'.
Link wrote:The other way is glancing at the info box; if you see the window that you want there, you made it.
t's also worth pointing out that the eye dropper and syringe will turn black when they are where they need to be, and when you eye drop the window, the window should become active in the toolbox. That's how you know you actually got the window.
‎2005-08-28 07:05 PM
‎2005-09-01 06:07 PM
‎2005-09-01 06:19 PM
kaykay wrote:So the eye dropper is full when you "match".... is it changing to a syringe when you "inject"? Is the syringe full?
yes i tried all that
the eyedropper is Full, when snapping to a Reference Line or axis node, but it doesnt transfer a dialog box's settings to an element,
Clicking an element doesnt apply the default values and attributes (Line Type, Pen Color, Material, etc.) to that element.
any suggestions?
Kay
‎2005-09-01 06:20 PM
