Assuming it is a composite wall then you need to edit the Building Material that is used in the composite.
Edit the BM to use a hatch fill rather than a solid (or empty) fill.
You can also set the default colours for the hatch lines and background there as well.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
