Attribute manager doesn't help....
These fills are such a pain in the ***
In some files there are no vectorial and symbol fills because they were initially .dwg files that I opened in ArchiCAD in order to continue working with them. The vectorial, symbol and image fills in ArchiCAD are missing.
I opened a blank document just to copy the fills from there and I hit another problem. Some fills, no matter how many times I changed their values in Fill Types appear black on the PDF. I see them when I zoom in but the zoom is 1000% , then I re-scale the fill in order to properly fit into the 100% but it becomes way larger and almost disappears as a pattern.....
I needed the gravel hatch from Autocad that looks like a stone wall but the hatch doesn't want to be scaled properly and neither does the gravel fill from Archicad. The latter remains black.
I'm clueless.
The 2D fills are not supposed to be so difficult to work with.
