Fills on Section
Hi Everyone,
Does anyone one how to add non-transparent fills with patterns. When I add fills over section cut fills they seam to be transparent.
Any help much appreciated.
cheers.
Stephen Dolbee
Martin,
Select the fill, go to Tools/Display Order, and Bring to Front.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Djordje
Change the fill background color to non transparent
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
you may also have to change your display option for background fills to "use element settings" or display background color". It sounds like you may have it set to all fills transparent.
Be sure you set the display option in plotmaker as well. for some reason PM doesn't assume you want the setting you saved in your view from AC.
HTH
