Before anyone else beats me to it, I should fess up now & admit that I missed something fairly crucial! - you CAN get a fill handle which allows you to adjust slab fills in 2D when you tick the "link to fill origin" radio button in the slab tool - however, if the fill is to be associative with the 3D texture, you need "use fill of surface material" enabled as well
With "use fill of surface material" on (i.e keeping fills & textures associative), you can not adjust the fill setout of slabs at all in the 3D window - tough when trying to align associative fills across walls & slabs - eg bathroom wall/floor tiling
Associative or not, you also cannot adjust the setout of fills in 3D except on the "dominant" face for the object type (top for slabs, side for walls)
You still can't adjust anything in an elevation window
Fills also get distorted on slab or wall edges by any angle that is not 90 degrees - forcing messy workarounds
My issues are really just reduced to one - we need separate associative fill/texture control for all faces, for all object types, and in all views
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-28 | Twinmotion 2024
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
