Frame around the window.
Gisele
I need to know what's this pink border frame, so I adjust its color/material.
When I isolate the window, I do not see it. Attached are screenshots showing the window's settings.
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
1 REPLY 1
This is window casing, you can check it's parameters via this dialog.
https://help.graphisoft.com/AC/26/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC26_Help%2F150-1_Doo...
AC 27 INT 5003/WIN 11
