2011-01-29
01:55 AM
2023-05-09
04:47 PM
Rubia Torres
2011-01-31 02:24 PM
jonyyybe wrote:The "lines" are "LIN_" statements that define lines in 3D. These are the source for the XYZ coordinates.
Nando, can you by more explinable.
Can you explain the exactly the steps in the ravoneldar dwg file uploaded.
1- open the DWG as an object - i understand
2- copy the 3D script to a text editor (just the lines=what lines? there are many lines) and save it as txt - i don't understan what lines, but to save to a txt yes.
3- open the file in MS excel (using commas as separators=???) - Using commans as separator?This is a basic spreadsheet standard. Text files converted to spreadsheets typically have commas or tabs as the separators between the data in the cells.
3- use find & replace to replace the LIN_ text with a space - same ????This is to delete the LIN_ command which the XYZ file does not need.
4- at this moment you will have 6 columns - remaning to be seen...This isolates just the XYZ coordinate values in the spreadsheet. I'm not clear about the instruction to place the columns at the end as I assume the procedure is simply to delete all but the thee columns.
5- take the last 3 and place them at the end so you can have a list of X, Y and Z values - ??????
6- save it as a txt , again using commas as separators - ?????See above.
2011-01-31 05:10 PM
2011-01-31 05:19 PM
2011-01-31 05:28 PM
2011-02-01 06:22 PM
ravoneldar wrote:I try not to do baby sitting when helping others. Nevertheless this is not an
could you please send the .pln file to my e-mail?
It's [email protected]
I need it so much!!!
2011-02-01 10:02 PM
NandoMogollon wrote:
I try not to do baby sitting when helping others. Nevertheless this is not an"out-of-the-book"procedure so I can offer you a deal:
Here is the TXT file you will need to create your Mesh, it is important for you to try to understand the procedure. Then you do your mesh.
