2023-03-08
04:24 PM
2023-05-09
02:19 PM
Rubia Torres
I have yet to figure out a clean and efficient way to draw exterior furred walls, so that cladding wraps around the furred wall properly and intersections look clean. This is the way I have figured out so far which looks the way I want it to, but it seems like an unnecessary amount of walls and construction lines are not clean,
Wall 1 (Core Outside): Cladding + WB + Sheathing + Stud 1 + Stud 2 + Gyp
Wall 2 (Core Outside): Stud 1 + Stud 2 + Gyp
Wall 3 (Outside Face): Cladding + WB + Sheathing
Wall 4 (Outside Face): Cladding + WB + Sheathing
Wall 5 (Core Outside): EIFS + WB + Sheathing + Stud 2 + Gyp
Building Material Intersection Priorities are set to the following:
EIFS - 480
Gyp - 300
Cladding - 250
Sheathing - 620
WB - 50
Stud - 615
Wall junction orders are set to 8, and the furred wall should be a single wall so that doors/windows cut through the entire wall. Does anyone have an idea for a cleaner solution?
Thanks!
Solved! Go to Solution.
2023-03-08 08:52 PM - edited 2023-03-08 08:53 PM
Hello @ocamorlinga,
In this case, I am modeling a custom column* profiles and I change the classification of these columns to wall for proper ifc export.
*... and beam !
Hello @ocamorlinga,
*... and beam !
2023-03-09 12:44 AM
I see.. so the corners of the furred wall are columns and then you connect the rest of the wall to the end of the column? Do the materials join together properly this way?
Thanks for your reply
2023-03-09 02:14 AM
Probably the easiest way to do all of these more complex connections. You can select your current walls and copy paste it into the Profile Editor, then edit out the lines you don't need and reduce it to just the junction.
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2023-03-09 08:54 AM
2023-03-09 04:28 PM
This solution works pretty well, thanks Christophe and Ling!
2023-03-10 02:07 AM
Remember to change the classifications and properties to that of the wall.
