2019-04-23 11:23 AM - last edited 4 weeks ago by Molinda Prey
AC22-28 AUS 3001 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2019-06-21 03:47 AM
dim pfsj2[] pen 1 for i = 1 to MULTIPLECO_A jdsl=0 !Calculate the number of points !----------------------------get profile number and geometry n = request{2}("Profile_components", myProfileIdx, jmsl, jglx) !profile number n = REQUEST ("Profile_default_geometry", myProfileIdx, pfsj2) !profile geometry if jmsl>0 then for i2 = 1 to jmsl !------------------------------------Collection point n = REQUEST{3} ("Profile_component_info", myProfileIdx, i2, "gs_profile_surface", _surface) !MAT for i3 = 1 to pfsj2[i2] jdsl=jdsl+1 !Calculate the number of points x=pfsj2[jmsl+5*jdsl-5+1] y=pfsj2[jmsl+5*jdsl-5+2] if pfsj2[jmsl+5*jdsl]=900 then sn = 900 if pfsj2[jmsl+5*jdsl]=4000 then sn = 4015 if pfsj2[jmsl+5*jdsl]=-1 then sn = -1 if pfsj2[jmsl+5*jdsl]=0 then sn = 15 put x,y,sn,_surface next i3 !------------------------------------MODEL SPRISM_{4} _surface,_surface,_surface,1+2+4+8, nsp/4, 0, 0, 0, 1,1,0, 0, 0, 0, 1,0,0, get(nsp) next i2 endif next i
2019-06-21 05:00 AM
2019-06-21 05:23 AM
Lingwisyer wrote:
The issue with using an array in the parameters to define the profile is that the selection can only be done byindexrather than by drop down and since you cannot view the index numbersanywhere other than the Attribute Manager, this is not a viable option. If we were able to use requests in the Parameter Scriptthis could have worked as then you could have a second and third dummie parameter with one being a standard profile selection, and the other displaying the index numberof the selected profile, but alas, this is not the case...
If you can modify parameter arrays via theUI Scriptthis might be possible, as requests work there. The extra work here may as well be used to duplicate standard profile parameters with additional HIDEPARAMETERstatements.
Ling.
2019-06-21 05:37 AM
2019-06-26 10:42 AM
