General rotation function
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-02-29
03:19 PM
‎2024-06-03
12:41 PM
Aruzhan Ilaikova
I know you can rotate a beam by typing in a slope. Is there any common function or button that works on any geometry to rotate the item in the x, y and z axes?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-29 05:07 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-29 05:10 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-29 05:41 PM
Laura wrote:If you do not mind paying look at
If I understand you correctly -- rotating an element in 3D, and not just restricted to plan? You might want to try Cigraph's ArchiRotate, which will rotateObjects. I haven't used it yet, so I can't make any recommendations, but because it's free, it wouldn't hurt to give it a try...
http://www.encina.co.uk/objective.html
Now a days it does that and al ot lot more.
Joseph
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-29 05:50 PM
AC tool elements like walls and slabs. I am not sure but I believe
this is also true of Objective.
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-29 05:58 PM
Is there an easy way to rotate say, a slab from flat to vertical? Or do you need to use a roof for any kind of sloped surface? The other day I drew a circle. Filled it with a slab and then tried to rotate it from horizontal to vertical. I wanted the curve in order to do an SEO.
If I had used a roof instead of a slab would that have given me the ability to rotate it 90 degrees?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-29 06:05 PM
Is there a simple way to rotate any object/wall/slab/geometry on any axis or combination of axes?No
AC V6 to V18 - RVT V11 to V16
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-29 06:08 PM
Seraphim wrote:I believe roofs will only rotate up to 89 degrees. You could, however, have made the "circle" slab into an Object to rotate it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-29 06:17 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-02-29 06:19 PM
you need think, what do you want to achieve and then think about the ac tool that will get you there...and make sense....if i want a vertical element, why should i use the slab tool? the wall tool would be more appropiate for that case, etc.
