2008-02-29
03:19 PM
2024-06-03
12:41 PM
Aruzhan Ilaikova
2008-02-29 05:07 PM
2008-02-29 05:10 PM
2008-02-29 05:41 PM
Laura wrote:If you do not mind paying look at
If I understand you correctly -- rotating an element in 3D, and not just restricted to plan? You might want to try Cigraph's ArchiRotate, which will rotateObjects. I haven't used it yet, so I can't make any recommendations, but because it's free, it wouldn't hurt to give it a try...
2008-02-29 05:50 PM
2008-02-29 05:58 PM
2008-02-29 06:05 PM
Is there a simple way to rotate any object/wall/slab/geometry on any axis or combination of axes?No
2008-02-29 06:08 PM
Seraphim wrote:I believe roofs will only rotate up to 89 degrees. You could, however, have made the "circle" slab into an Object to rotate it.
If I had used a roof instead of a slab would that have given me the ability to rotate it 90 degrees?
2008-02-29 06:17 PM
2008-02-29 06:19 PM
