2007-01-31 10:53 AM
2007-02-02 12:52 AM
Steve wrote:Autodesk has never said that. Working for a reseller during that time when ADT users were fearing the worst, that was never the party line. They now acknowledge that ADT doesn't succeed very often at BIM (though it can if you can just learn everything about that wretched piece of software), so the message has changed over the years.
I remember when Autodesk was publishing on their own web sites about how ADT was going to be discontinued
2007-02-02 01:23 AM
2007-02-02 06:31 AM
Steve wrote:Change the size of a door in a schedule and it will update instantly anywhere else it occurs in the project. Plan, section, elevation, 3D, perspective...
Tell me something you can do with Revit you can not do with ADT?
2007-02-02 07:29 AM
2007-02-02 08:48 AM
2007-02-02 05:51 PM
2007-02-02 06:34 PM
metanoia wrote:and to further what Wes said....some companies are working on specification software for Revit, where you can change an item in the TEXT of your spec, and the model will update. Full Bi-directional associativity is hugely powerful.
Why is it wrong? It's powerful and convenient, and I wouldn't be caught without it. Don't knock it til you try it😉
Revit users do complain about some things Revit does -- this is not one of them.
2007-02-02 07:23 PM
Scott wrote:That's a major point in the BIM industry: You should be able to edit something anywhere you see it. It's up to you to make sure if updates in a way that makes sense.metanoia wrote:and to further what Wes said....some companies are working on specification software for Revit, where you can change an item in the TEXT of your spec, and the model will update. Full Bi-directional associativity is hugely powerful.
2007-02-04 12:04 PM
2007-02-04 10:38 PM
Tomtomas wrote:Sure...but sometimes we make mistakes graphically in a 3D model. Quick, tell me which door in this 3D model needs a correction? Then look at the difference in a tabular format....it stands out like a sore thumb! Being able to make these changes in the schedule to drive the model are valuable. Imagine this was a project with 600 doors? Go find the wrong one in that project model to fix it....ugh!
And the most sensible way for the architect to make changes in 3D model is to edit 3D model itself, not the schedule. It's the easiest way to avoid modeling mistakes.
