Glass railing appears as brick
MartaCatela
Hi, I just started with archicad 1 month ago so this might be a dumb question but my glass material on railings appears as being brick (see pictures) .
How can I get it to be actual glass?
[On windows and doors glass appears correctly, it's just happening in this specific thing.]
Could someone help me? Thank you!
David Maudlin
MartaCatela:
Select the Railing, then in its settings dialog box look at Railing > Segment > Panels > Panel Component Settings > 3D Representation > Building Materials and Surfaces.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
MartaCatela:
Thank you so much for the help! 🙂
