Graphic Overrides for window/door frame surfaces
Hi there,
Is there a way to apply a graphic override to the window/door frame surface only, without changing the glazing material? I was trying to achieve it by using Surface and Surface Name criteria combined with the element type set to window, but it didn't work. Is there any hope?
Cheers
1 REPLY 1
Podolsky
Ace
No, you cannot override only part of the element.
