Graphic override rule to make all widnows empty holes
Hii!
I would like to show all windows empty in the floorplan as I can do in 3d view (with filtering elements in 3d).
Is there any way to achieve it in floorplan as well, I guess with graphic override rules?
I didn't create empty windows openings from the beginning, because I would like to have an option to show or hide the windows in floorplans and sections.
I'm not successful so thank you in advance for any kind of advice.
1 Solution
Erwin Edel
You can do this with model view options. If you look at Construction Element Options you can set Door, Window and Skylight to Show Opening Only.
You can even completely hide them (meaning you will see a wall or roof without the hole).
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Go to post
3 Replies 3
Erwin Edel
www.leloup.nl
vistasp
Mentor
To do that, you should use the Model View Options (MVOs)
EDIT: Looks like Erwin already answered it.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Oh, yes! Forgot about that as not being a regular Archicad user,
Thank you. It worked!
