We value your input!
Graphic override rule to make all widnows empty holes
Hii!
I would like to show all windows empty in the floorplan as I can do in 3d view (with filtering elements in 3d).
Is there any way to achieve it in floorplan as well, I guess with graphic override rules?
I didn't create empty windows openings from the beginning, because I would like to have an option to show or hide the windows in floorplans and sections.
I'm not successful so thank you in advance for any kind of advice.
Erwin Edel
You can do this with model view options. If you look at Construction Element Options you can set Door, Window and Skylight to Show Opening Only.
You can even completely hide them (meaning you will see a wall or roof without the hole).
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Erwin Edel
www.leloup.nl
Windows 10 Pro
vistasp
To do that, you should use the Model View Options (MVOs)
EDIT: Looks like Erwin already answered it.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Oh, yes! Forgot about that as not being a regular Archicad user,
Thank you. It worked!
