ā2017-05-31
10:52 AM
ā2023-05-23
02:17 PM
Rubia Torres
ā2017-05-31 11:09 AM
ā2017-05-31 02:50 PM
ā2017-06-01 05:02 AM
GeorgieB82 wrote:Sure if it is a renovation filter problem then you can change that in the renovation filter settings. You will want to change the override settings for either the 'new', 'existing' or 'to be demolished' status - depending what that element has been set as.
Can I change the default colour so on the rare occurance this happens that it will be less noticable?
ā2017-06-06 10:53 AM
ā2017-06-06 11:19 AM
Erwin wrote:Yes thanks for the clarification Erwin, I meant texture instead of material.
Barry, that would be a missing texture.
ā2017-06-06 11:33 AM
ā2017-06-07 07:49 AM
Erwin wrote:Yes I use coloured pens and black/grey for publishing.
Are you showing your pens as black in 3D?
I allways work with colour pens in all my views, and assign the black pen set only to the placed drawings on layout.
