2005-11-28
09:00 AM
2023-05-26
03:11 PM
Rubia Torres
2005-12-13 01:07 AM
2005-12-13 01:41 AM
2005-12-13 02:06 AM
2005-12-13 04:41 AM
kSchnieder wrote:copy paste will often "fix" a corrupted element even in the same file-- This was strange - I tried reloading libraries, merging to new template, etc. to no avail. The problem persisted on all types of windows. So I tried just COPYing external wall, internal walls and other parts, all seperately to a new template so I would not have to re-draw the floor plan. There must have been something in the drawing that got corrupted that did not COPY over because now it works ????
2005-12-14 03:03 AM
2005-12-15 12:03 PM
Zobi wrote:Zobi,
do these elements just sort of corrupt on their own?
I just replaced all the windows in this little house I am working on...maybe 20, or so, not a lot, but after each window swap (old and complaining for new and bright) I would look at the facade to check for errors. nothing...I went all the way around the house, one wall at a time, and everything looked good. then when I got BACK TO THE WALL I BEGAN with, I started getting error messages..! just 2 so far, but my max is a whopping 46! I want this to NOT happen, but I can't seem to find any, single variable that needs to be tweaked just So to make it happy. Maybe chocolates would work.
2005-12-15 06:37 PM
2005-12-23 03:15 PM
2005-12-24 04:09 AM
dmoraca wrote:Most probably.
Does anyone know what I have done wrong so these errors are coming up when I do building section or 3D view.
ArchiCAD 9 with AC9 SE Library.
Could it be window Error
2006-01-04 03:13 AM
