Gutters
The gutter tool has a problem...
when I had both ends set at 45 degrees...all is well in the universe.....
when I had to change one end to a 90 degree...the gutter becomes 90' long, the angle doesn't/won't change. I can make this happen over and over...but would like someone to figure out a solution to this
There is a glitch in the tool itself, in that there is a problem with the right angle, and every time I try to change it, the gutter itself changes....
however, all this being said, when I set it to 0 degrees, it works....
0 Replies 0
