HIdden layers got deleted, after unhide the same layer
Roopa A
I have created separate layers for dimension for different purpose like working drawing, excavation, beam column layout like that.
So when we don't want the layers I made it hide, then again if I want it, and made unhide, the dimension is not there, where I am going wrong, please help me in this.
I am using layer combination for this
Roopa A S
Have you changed the partial display options?
Dimensions placed in one partial display option will not show in the others even when the correct layer is on.
They are linked to each partial display option.
4 REPLIES 4
If you turn all layers on, do you see your dimensions?
Roopa A
No, dimensions are not seen, but the layers are there.
I could activate the layers and used select all , but the dimension are not there.
Roopa A S
Ya this worked, the partial structure display is on.
Thank you sir.
Roopa A S
