Half Stone Half Brick Wall
What would be the best method to model a wall where the water table is like 5' off the 1st finished floor and it is stone with a stone lip and then everything above that wall to be brick. (We do different height water tables all the time).
Also on the hunt for a cover fill or lack of better words a "hatch" for a wall representing the different kinds of stone. Stack stone, river rock etc. Just would like to be able to draw the walls like the structure will be built so when shown in 3D it would show the different materials.
19 Replies 19
Another option is Dwight's technique in this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?t=14945
Also this thread which addresses this particular wall better:
http://archicad-talk.graphisoft.com/viewtopic.php?t=20472
David wrote:
Barry wrote:
Still doesn't show them properly at door/window edges but maybe this could be solved with some creative scripting.
I don't think there are Global Variables available in GDL to get enough information about the host wall to accomplish this automatically.
David
Not to do it automatically.
But it would be possible to create parameters for manual input of the height and material for the stonework so that a thin veneer could be modelled at the side of the opening.
Far from a perfect solution though.
My issue is that when I try to change the material like shown above in other suggestions, it is greyed out and non-selectable. I tried several different ways but it always shows brick, and I cant change it anywhere.
Is that a bug? like my file has something wrong with it, or I made the profile wrong or is it something that can be fixed?
Only the end surface of a complex profile wall is editable in 16.
The other surfaces must be edited in the Profile Editor.
Is this end surface greyed out for you as well?
Erwin Edel
I've tried to figure this out in the past, but nope, the GDL variable returns the material the window/door 'hits' at the bottom, you can't get multiple materials.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Understandable as a complex profile could have any number of materials at any location and any shape.
So you would have to add some parameters for the manual input of materials and material heights.
Probably easier to add small walls to the inside of the openings as mentioned in the linked posts that Karl mentioned.
I am on 17. It just seems like that if I make a complex profile, bottom stone, a stone cap and then brick on top it would clean up per material on the elevations. I just get the default brick shown.
I am lost on the "little walls" idea. It shows where I could change it if need be but it is greyed out. Oh well, I am just going to make separate walls that clean up correctly.
Thanks for the help though.
I did contact a friend and they changed it for me with no problems, but I don't have the option to change it. Not sure why he could and I can't.
Those surface buttons work differently in AC17 than in previous versions.
In AC17 there is an Override activating button to the left of each long Surface button. This is because the Surfaces of Wall skins come from the Building Materials. If you activate the Override for any of the sides (outside, inside, edge) you can define an override for that surface.
In AC16 and before these long buttons were always enabled so there was no need to activate an override button.
In the Construction Elements page of the Project Preferences Dialog, you can use the "Use legacy intersection methods for model elements" checkbox to switch between how elements intersect. If the checkbox is turned off, those overrider buttons have a role, if it is checked, they do not.
So I think the state of this checkbox was different for you and your collegue.
I also had this problem in one of our projects. I kinda solved it using empty openings. I used an empty opening for each layer of material. I found out that you first have to insert the empty openings and then the door. I did add hotspots within the complex profile so I could snap the openings to the correct height. Not the ideal solution but it works...
